Cracking aluminum and powder coating
When we try to powder coat an aluminum cylinders, approximately 4" in diameter, they crack during the process. Any ideas why?
Stephen MurphyManufacturing - Houston, Texas
Need a bit more info. At what stage of the process do they crack? What pretreatment are you using? What cure temp? time? Whats the cylinder? thick wall, thin?
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
