  Thread 280/44
Coating process for corrosion-free fasteners
Dear sir,
We are manufacturing Ground Power Equipments for all kinds of Aircrafts. We are facing a lot of problems particularly with all kinds of fasteners we use. Currently we are using green passivation for hex head fasteners. I request you to suggest me to choose what kind of coating should be used to get 100% corrosion free with relevant growth thickness.
S.Manickaraj
electronic manufacturer - Coimbatore, Tamilnadu, India
publicly reply to S.Manickaraj
No coating process will deliver 100 percent corrosion-free fasteners, but I suspect you already actually know that. The zinc plating with olive drab passivation that I assume you are using is already a pretty good finish. It can be improved by switching to an alloy zinc plating like zinc-nickel or zinc-cobalt, but what wasn't clear to me was whether the fasteners corrode before they are installed or after. If after, the first question is what are you joining together--because you may be encountering galvanic corrosion.
publicly reply to Ted Mooney
Dear Sir,
The most cost effective solution for you will be to zinc iron or zinc cobalt plate your fasteners as Mr TM has suggested above.
We can do this for you; we have probably the largest alloy plating facility nearby you for this kind of work.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
