How to Patina Copper
by Hughes & Rowe
AbeBooks
I would like to know the fastest way to age copper without using chemicals. And if I have to use chemicals what is the best product to create patina on copper and where can I get it in the New Orleans, Metairie, LA area? Thanks, Tara
Tara Rabalais- Chalmette, Louisiana
Hi, Tara. "Patina on copper" is the topic of dozens of letters here, so can search the site to get a lot of people's different perspectives; but if you want a very organized presentation on all the different colors and how to get them, you could look for "The Colouring, Bronzing & Patination of Metals" by Richard Hughes and Michael Rowe next time you're at the library.
But if you are looking for the blue-green patina associated with aged copper, probably the easiest way is to brush on a commercial patinating solution.
Copper Tubing
I am trying to put a green patina finish on copper tubing. My question, is it normal for the copper tubing to turn very dark when the solution is applied?
I cleaned the copper with steel wool
⇦ this on
Amazon [affil links] .
then washed with muriatic acid ⇨
and rinsed off.
The patina did appear but am unsure about the very dark copper.
Jeff Rodkey- Chambersburg, Pennsylvania
Why do copper domes and the statue of Liberty turn green and not black as they weather? Natalie Hake- St. Louis, Missouri 2001 Because the corrosion products of copper exposed to this environment are green rather than black, Natalie. I think you'll find that copper turns brown first, then green over time. ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey 2001 |
Do the
Prismacolor markers
[affil links] create a nice red color on copper? I used
liver of sulfur
⇦ this on
to make the flowers black, the second part is to use acrylic paint the closest possible in color to the metal(the black color after the liver sulfur or the copper color?); and then use the color pencils in layers.
Teaching/special ed. - Naperville, Illinois
Believe it or not, "EASY OFF" oven cleaner
⇦ this on
Amazon [affil links] sprayed on a clean copper surface will blacken it as it dries. Use more coats as needed.
If you are making Mission style hardware, you need to get quite dark. several coats will be needed. I liked three.
- Lancaster, California
September 22, 2008
