Want non-CN diffusion brass plating on wire
I wanted information on how to get diffusion brass plating (70% Cu & 30% Zn) 0.9-1.3 micron thickness on fine wires. The continuous plating bath should be non cyanide electrolytic base.
Dinesh Gudadhe
Wire Technology development - Mumbai, Maharastra, India
Mr Gudadhe,
It is possible to plate brass from a Non Cyanide solution. You need to look at the various Alternative Clean Technologies replacing cyanide world wide to come up with the acid brass Plating solution.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
