Diffuse coating on smooth surface
WE have been asked on several occasions to provide a diffuse coating on a flashlight reflector. When the we receive the reflector it is smooth and the customer wants the surface to be textured like textured plastic in order to achieve the diffuse coating. Are there any paints, process, or other that can achieve this texture before we evaporate the aluminum on it? Any help would be appreciated.
Glenn MuellerVP - East Bridgewater, Massachusetts
You should be able to get the diffuse finish by bead blasting. You'll have to play with the size grit, et al., to get the surface the way you want it, but bead blasted surfaces are easy to coat. Just make sure you thoroughly clean the parts afterward. Very often the grit will stick to the surface.
PVD Consultant & Wine Lover
San Diego, California
Glenn,
You forgot to tell us what the base material is. Also, are you going to basecoat it, or are you using the direct metallization process?
