Surface finish formula
I have a job requiring a surface finish of Ra 1.25 to 1.35 Is there a speed and feed formula I can use to accomplish this finish? I'm using a cnc machine with a 3" dia. cutter, and the material is nickel. Thank you, any help you can offer will be appreciated.
Mark LathrupCNC Machinist - Sterling Heights, Mich, USA
For that kind of finish conventional CNC machines are not an easy option. Machines capable of that are specialized high precision extra stiff single point diamond cutting tool lathes. Certainly not for every kind of geometries. The common alternative is grinding and laping or craftsman hand stoning and polishing depending on how complex the shape is and of course volume.
You might use CNC grinding machine. I know that there is a supplier for such machines that can finish Ra less than 1.0
Alfred Kung- Hong Kong
