Thread 276/36
What is Galvanneal?
What is Galvanneal and I need a MSDS. I need to know because I am employed at a steel mill and the boss is asking about this product.
Sylvia M. McCainBuyer in Purchasing - Roanoke, Virginia, USA
publicly reply to Sylvia M. McCain
Galvanneal is a hot-dip zinc coating applied to steel. It is similar to hot-dip galvanizing but is specifically designed for steel that will subsequently be painted, such as the rocker panels and other corrosion sensitive areas on cars.
If your mill sends the steel out for galvannealing, the shop that applies the galvannealing should supply you with the MSDS. If you do the galvannealing in house, you need to generate that MSDS yourself. Your mill surely has a position equivalent to Director of Safety and Environment. That person should be able to help you.
publicly reply to Ted Mooney
Galvanneal is the same as galvanized except it has iron alloyed with the zinc in the dipping bath.
Ronald ZeemanCoil Coating - Brampton, ON, Canada
publicly reply to Ronald Zeeman
An (liquid) zinc Bath alloyed with 10 % iron is impossible. Galvannealed steel strip is produced from Galvanized steel strip via an strip heating (500 °C for some seconds) , where iron diffuses into the zinc (and vice versa).
Alexansder Jarosik- Linz, Austria
publicly reply to Alexansder Jarosik
