Petrol resistance - 2k PU system
Q. We would like to know about the Petrol resistance of PU lacquer (2 K) system, suggest the test method to evaluate the performance in Petrol resistance test.
R S NarasimhanFinishing Manager - Chennai, Tamil Nadu, India
A. Dear sir,
The double rub test should be okay for this. Soak a cotton cloth with petrol, vigorously rub over the cured coating several times. Rubbing twice is a double rub. Calculate the number of double rubs required to soften the coating. Normally 50 double rubs is a pass. If you put stringent Quality control, then 200 double rubs may be okay.
Dinesh [last name deleted for privacy by Editor]- Chennai, Tamilnadu, India
Q. Which standard is this petrol rub test taken from? Which product labels should use this test?
kiran jose- United kingdom
September 15, 2015
