Coloring aluminum like gold
What is the procedure or method to color the aluminium similar to look like as Gold?
V.JayaramanExecutive Foreman - Hyderabad, Andhrapradesh, India
You probably are talking about bright dipping the aluminum, anodizing it, dyeing it with gold dye, and then sealing it. On the other hand, aluminum can be gold plated, and other coloring technologies exist as well, but the anodizing route is common and relatively inexpensive.
