Advantages of Enamel Coating over paint and other coatings
Q. What's the special advantage of enamel coating. Is it for withstanding High temperature? If it is, how high is the permissible temperature before the coating breaks?
Jeffrey T [surname deleted for privacy by Editor]
finishing related engineering - Kuala Lumpur, Selangor, Malaysia
A. Enamel coating usually apply on steel surface for rust resistance, it normally can stand 700° C, some enamel coatings may mix with porcelain powder that can achieve 200& deg; C more.
Daryl Y [surname deleted for privacy by Editor]
- Hong Kong
Q. Dear Sir,
My company is working in the field of Manufacturing House Instruments. We apply Enamel coating on Steel. So I need to have some documents regarding the preparation of enamel and method of application.
Dr. Ibrahim G [surname deleted for privacy by Editor]
- Cairo, Egypt
Q. Can I know what is enamel coating? Where can I find the information for this?
Ten Wai Keong
- Kuala Lumpur, Malaysia
February 10, 2008
