Suggestions for start up of zinc phosphating business
I have a question regarding what I Need to have to get started in the zinc phosphating business. I.E. Testing Equipment, Cleaners,Chemicals,and number of tanks. I will be doing parts to federal specs TT-C-490 [from DLA] Method 1,3,5. Type 1. Any and all information will be very helpful.
John Kelly
Machine Shop Supervisor - Ellington, New York, USA
Start with the chemicals suppliers, e.g., HeatBath, Henkel, Chemetall, etc. -- or click "Chemicals and Equipment" button below. Product bulletins recommend pretreatments, tank and heater material, rinse water purity, post-treatments, simple pH and titration analyses, etc. Use the representatives“ knowledge as to which set-ups work and what laboratories can perform salt spray and other tests. Also, try "Test equip. & Testing Svcs." below. Also, you will need to deal with local EPA and wastewater district re treatment permits and equipment. Note that a chromated rinse is required unless otherwise specified (some non-chromated sealants are available -- click "Chemicals and Equipment", you probably have Cr, Cr+6, pH, phosphate, and Zn effluent limits, and you will generate phosphate sludge. Perhaps, a chemicals rep can arrange a visit to an operating phosphating facility.
With a good idea of the maximum size of your parts and necessary equipment, perhaps have it fabbed by someone listed in "Chemicals and Equipment". Ask for a visit to a phosphating facility that they have built. On these visits, request a wastewater flowchart for help in sizing and permitting your WWT system.
It is wise to seek info in advance of startup. Good luck,
Ken Vlach [deceased]
- Goleta, California
Ed. note: Thanks for the promotion of our advertisers, Ken. While our advertisers do not represent every possible supplier, folks, they are a pretty fair cross-section. And the old saw applies: if you like the forum, please support the people who make it possible.
