Tarnish on pennies: Is it rust, copper oxide, or copper sulfide
Q. Why are pennies coated with copper oxide when they are made? I am questioning because I came across your site and was reading answers you had given to science fair questions on juices cleaning pennies. You aroused my curiosity!
Jan j.
student - Chapin, South Carolina
"Prizewinning Science Fair projects"
A. They are not coated with copper oxide when they are made, Jan. They are plated with copper metal, but the copper metal eventually tarnishes into copper oxide.
Why they are plated with copper is explained in other threads on this site: Copper got too expensive to continue to make pennies out of, so the mint started making them out of zinc. The copper plating offers some corrosion resistance, while leaving them looking like pennies are expected to look.
A. It is not copper oxide on tarnished pennies but copper sulfide.
Simon Dupay
- Roseville, Minnesota, USA
I don't agree, Mr. Dupay. It is true that tarnishes and patinas can be more complicated than just a simple oxide--and often involve oxides, hydroxides, carbonates, sulfides, and more. But I believe that the common brown tarnish on pennies is primarily oxide not sulfide. The 'black' tarnish on silver is sulfide though.
Sulfide forms a very tough tarnish on copper, but by far, the largest form of tarnish on copper will be an oxide.
A. Ask any chemist or metallurgist and they'll say it's a sulfide not an oxide. When copper forms an oxide coating (the green stuff) it's copper carbonate this on eBay or Amazon [affil links] And you have to heat copper to get the black oxide. So I have to say you're wrong Mr. Mooney.
Simon Dupay [returning]
thumbs up signI've been wrong a hundred times if not a thousand times on this forum, Simon, and always appreciate being corrected. You could be right, but you haven't given me any reason at all to re-examine my belief yet, and continuing an unsupported "is not!", "is so!", "is not!" debate would just be foolish, and a poor lesson for students who come here to learn about the scientific method.
I looked up copper chloride, oxide and sulfide. Chloride is minorly soluble in water, so it is probably not that. Also it is greenish. Sulfide and Oxide of copper in the valence state of II are both a shade of black or very dark blue and are both insoluble in hot water. Considering that there is many more times more oxygen in the air than sulfide, my money goes with oxide. Note that you can smell hydrogen sulfide in the low ppm range. So, if you do not live in Newark, bet on the oxide.
Ed. note: The open dumps/landfills of Secaucus have been gone for at least 4 decades, maybe more. Re-acquaint yourself with the Garden State :-)
? Now, I know that I don't have the chemistry/metallurgy background that a lot of ya'll have. But it seems to me, that in order to have a sulfide, don't you have to have sulfur present ... and for an oxide, oxygen present? If it's copper sulfide, where does the sulfur come from?
Marc Green
Marc Green
anodizer - Boise, Idaho
A. Well sulfur this on eBay or Amazon [affil links] is present in epson salt, when coal is burned with whatever amounts of sulfur, and also in many lawn fertilizers.
Scott B. [surname deleted for privacy by Editor]
student - Loganville, Georgia, USA
I'm doing a science experiment about how different liquids affect the "rust on pennies". I need to know if it really is rust. And if it's not then could you please tell me the name of what all the brown stuff is on copper pennies? thanks.
Jacob B
research - SW Ranches, Florida, US
A. Ok, well, please do not call it rust on a penny because it's tarnish!
Alexandrea S
- Denver, Colorado, USA
April 18, 2011
A. Jacob, you need to be more descriptive about the brown "stuff" on the outside of a penny (tartar or copper?)
Your friend, Hayden
Hayden A.
student - Torrance, California, US
A. Hi. But one thing it's not is rust. Rust is oxides of iron and there is no iron in pennies to get oxidized and form rust.
My name is Connie and I'm in the seventh grade and I'm doing a science fair project on pennies and the substances that clean them. The substances that I am using are; ketchup, vinegar in bulk on eBay or Amazon [affil links] and salt for an experiment to get the tarnish off the pennies.
But I'm getting confused about copper (l) and copper (ll) oxide. Does copper (ll) oxide produce worse tarnish on copper, like making it more dull than copper (l) would, or resulting in a patina forming on the copper?
Thank you, hope you read this in time! It's due tomorrow, kind of shoved it off a bit.
Julia Hambuchen
- Conway, Arkansas, USA
A. Hi Julia. Yes, we're still here, but this is a public forum, not a homework hotline, and help is unlikely to be close enough to real-time to help students who wait until the last day. My own experience is that I sometimes find blue-green pennies between the boards of boardwalks and similar places, and I sometimes see blue-green corrosion on copper water pipes -- but I never see blue-green pennies in circulation and being handled.
This seems to indicate to me that the brown tarnish on pennies is quite abrasion resistant and stable, whereas the blue-green corrosion apparently wears off rather easily. I've noticed a similar effect on brass and copper awnings and roofs: where the rain drops land gently, I see a blue-green patina build up, but at drip lines from a roof above, I see only brown.
Although Wikipedia reports that Cu2O is red to yellow, and that CuO is black, the coloration of copper corrosion products is very complex. The tarnish color can be affected by particle size, water of hydration, and other anions which may combine with the copper, like carbonates and sulfides. copper sulphate this on eBay or Amazon [affil links] and copper chloride are blue, so I'd say the corrosion that tends toward blue-green corrosion is Cu++. Copper cyanide is more brownish, so I'd say the browner corrosion is probably Cu+, and that Cu2O is the more prevalent tarnish which endures on pennies, which gradually converts to Cu++ oxides and salts -- but I don't actually know for certain what percentage of the typical brown tarnish is CuO, Cu2O, or other corrosion products.
December 9, 2014
What happens to copper sulfide tarnish in an acid bath?
Q. Will an acid wash, say HCl, remove a sulfide tarnish from copper? And, if so, does the acid simply release H2S as a gas, restoring the original clean copper surface? Or does it dissolve off a copper sulphate, copper sulfide, or some other copper salt from the surface of the copper? Thank you!
Deane Little
- Boulder Colorado USA
February 11, 2015
A. Hi Deane. Sorry, I have no idea. If your question is a school homework question, I hope someone can give you a theoretical answer.
But if it's a real world question, please try to explain your actual situation because that invariably produces more realistic & helpful answers than abstract questions do. Thanks.
March 2015
Do I use black copper for thermite, or green?
February 3, 2018
wikipedia
Thermite
Q. So when making copper oxide, what part should I use -- the green or the black to make thermite? Because my solution is turning brownish green almost black. Should I stop? What part should I use to make thermite, the black or the green?
Joe nalley
- Warren Ohio
Hi Joe.
Copper (II) oxide, CuO, is a mild oxidizer and is black, but can be green when hydrated (water molecules included in the compound). But I don't really know what "solution" you are talking about and what "stop" means in this context -- what is it that you want to stop doing or continue doing? Please clarify, and also introduce yourself; you may be completely qualified to make thermite and to work with dangerous stuff, but readers don't know whether that is the case or if you are just recklessly playing with possibly explosive powders like red copper oxide. Thanks.
February 2018
A. Hi all, I have tested the tarnish [on pennies] and it is copper oxide.
Saida
Saida Sanders
- Birmingham, England
February 24, 2020
