Ni plating on Ni-fe alloy without affecting lead-based glass
Q. I have a product that is comprised of two plates of ASTM F15 (Ni-Fe) fused together using a lead-zinc-borate glass. The glass fuses to the oxide formed on the surface of the metals. I would like to subsequently Ni-Au plate the Kovar, but I am afraid that the lead based glass will not withstand the process, i.e. it will also become active and plate. I have heard that with very low current density, it is possible to plate the kovar without affecting the glass. I have also heard that this is being done on dual in-line packages.
I would like any information regarding the possibility of this process.
James Petri
mechanical designer - Wenatchee, Washington, USA
A. James,
Glass is an insulator and will not plate when done electrolytically. You have to descale kovar to remove the scales formed during the sealing operation to get a good adhesion. Similar process is used for the manufacture of reed switch. Ni/Fe wire sealed on to low melting glass thus hermetically sealing the working environment. DIP can be can be done without problem.
Good Luck,
Karthik Thambidurai
electronic components - Norwood, Massachusetts
