316 vs 316L for see water use
I need to install stainless steel anchor bolts in see water. Does anybody knows the difference between SS316 and SS316L in regard of resistance to corrosion ? (I heard that there is no difference between both except the 316 will loose its characteristics if you weld it.) Thank you for your advice.
Laurent Accorsi
civil engineer - Abu Dhabi, UAE
Typically, 316L will have a greater corrosion resistance in a chloride (seawater) matrix. The L designation refers to a low carbon steel.
James Totter
James Totter, CEF
- Tallahassee, Florida
316L will definitely give you better salt water resistance.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
