Thread 272/52
Removing nickel and repairing decorative chrome plating
Hello,
I have problems removing nickel from a certain product made both out of iron and copper. It's iron welded together with some copper based alloy. I would need to remove it quickly and as cheap as possible not to damage the original surface. Also need info about a good Ni - strike for dechromed nickel surface and how to deplate the chrome (I do it with HCl). In both cases the original product is deco-chrome plated.
Thanks for all answers.
plating engineer - Maribor, Styria, Slovenia
publicly reply to Dimitrije Stopar
To strip nickel from steel, copper or aluminum the following is common knowledge (hope this is O.K. Ted). Anodic treatment in 600 mL/L sulfuric acid at room temp, 6 V using lead anodes (Glycerine or copper sulphate ⇦ this on eBay or Amazon [affil links] is commonly added to reduce risk of pitting). In you case having two different metals welded together makes it a challenge.
publicly reply to Guillermo Marrufo
Thanks Guillermo. Anything that is either common knowledge or comes from someone we know is fine. The problem that sometimes arises is people offering detailed formulas but identifying themselves only with a free disposable e-mail address; then we have to worry if they are trying to blow a former employer's secrets :-)
publicly reply to Ted Mooney
Thank you Guillermo. Any information helps me very much. What may be common knowledge for some, may be unknown for someone else.
Dimitrije Stoparplating - Maribor, Styria, Slovenia
We want to find out an easy way of deplating nickel coating (40 micron) An anodic treatment of sulfuric acid with 6 V using lead anodes was suggested earlier, however I need more details.
In addition would you please let me know how to provide health and safety rules, any gases coming out might cause big problems
plating - Istanbul, Turkey
publicly reply to Nesligul Wagner
