Thread 272/46
What protects nails from rusting best in different solutions?
My name is Tyler, I'm in the 5th grade and I want to do my science fair project to see what the difference is on the rusting of nails in water and then in vinegar ⇦in bulk on eBay or Amazon [affil links] , using coatings of nail polish, hot glue and one with nothing, what is the outcome of this project?
Tyler B.5th grade student - Waurika, Oklahoma
publicly reply to Tyler B.
You are very young, Tyler, so you may not know this yet, but you are supposed to do the experiment and present you results based on what you find. After you have done the experiment, that would be the right time to ask if the results you got were what should be expected.
publicly reply to Ted Mooney
I need help on that too. I need info on rusting nails. but I'm in 7th grade. how long do you believe nails take to rust? anyone? I need to see if I can do that for my science fair project please help!
Melissa S.- Avon, Ohio
publicly reply to Melissa S.
I think you should plan on two weeks, and I don't think there's much chance of getting a reasonable amount of rusting in less than a week. I'd suggest putting the nails vertical, though, part in and part out of the liquid because I think the most rusting will be right at the water line.
