Magnesium Mated to Printed Circuit Board
I am designing an electronic enclosure which is to be made of thixomolded magnesium AZ91D. We will be fastening a PCB with exposed soldered (tin/lead) surfaces directly to the magnesium for electrical conductivity. The electronic enclosures are rated for use in indoor environments only (-10° to +50°C, 90% Relative humidity, non-condensing). What surface treatment for the magnesium do you recommend?
Erik Tews
mechanical engineer - Fresno, California, USA
When electrical conductivity is necessary, the choices are quite limited, with electroless nickel plating being the most common. You will need to work with your molding/casting supplier to insure that the surface of the parts is adequate for the electroless nickel process.
Toby Padfield
Automotive module supplier - Michigan
Do not make electroless nickel, it will accelerate galvanic corrosion. Ask Oakite (Chemetall) about OXSILAN MG 0611.
Ilya Ostrovsky
Surface Treatment - Germany/Israel
