Al 6061T6+Hardcoat anodizing+Saltwater fog= still not working
I am currently working on a project for a medication delivery application that requires plates of Al 6061-T6 in a saltwater spray/fog environment. They still corrode despite the fact that we are using hard-coat anodizing for corrosion resistance. Are there any other methods (subsequent or alternative) that can be used that will avert corrosion a little better than the current strategy?
Joe Bigalkemechanical engineer I - Round Lake, IL, US
Was the anodizing sealed? Was the corrosion examined using a magnifying glass or microscope? Is hard anodizing required for abrasion resistance? Try conventional anodizing (MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA]F, Type II), sealed. For corrosion resistance, a thin, intact layer is better than a thick, "crazed" one (cracked from differential thermal expansion vs. the Al).
Ken Vlach [deceased]- Goleta, California
Hardcoat anodize should have very good corrosion resistance in a neutral salt fog environment. What is the pH of your system? Sealing, not normally done on hardcoat, will further improve corrosion resistance.
Chris Jurey, Past-President IHAALuke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
