Refinishing musical brass instruments
Q. I am a musical instrument repairman and I have a vintage saxophone that has a large spot of rust on the bell over the engraving. How do I remove rust from brass musical instruments without hurting the rest of the finish?
Dan FlemingSaxophone repairman - Clear Spring, Maryland, USA
Your best bet would be to have someone replate the instrument.
Jake KochG. J. Nikolas &Co.,Inc.
Bellwood, Illinois
It is not possible to do spot brass polishing on your horn. The finish is no doubt old and any attempt at polishing will make one area look much better than the rest. The horn needs to be stripped and polished by hand or buffed on a machine.
Dean WallaceMetal restoration - Wilmington, North Carolina
Q. I just got a saxophone from a friend and it is a bit rusty... how can I take the rust off without having to re-plate it or taking it into a special person?
Lauren N.student - Sydney, NSW, Australia
Hi Lauren. Any good brand of metal polish is what you're looking for.
June 2013
