Stripping rust with alkaline solution
I made a solution of common laundry detergent(tide) and mixed it with hot water and used a battery charger this on eBay or Amazon [affil links] ; negative to the item to clean and the positive to a stainless anode-bar. The resulting action was after a couple of hours a rusty foamy scum on top and the removal of quite a bit of rust from the steel part. It left behind a real black coating on the part which I could eventually scrub off. Was any of this residue harmful in any way? It sure stained my hands like carbon would.
Pete Prosser
hobbyist - Moncton, New Brunswick, Canada
Without knowing what the item was, it's not possible to say whether the procedure was harmful to the item. It can become hydrogen-embrittled if it's a high strength steel. If the item was steel, I doubt that any corrosion product could be dangerous to people. It's probably just "smut".
