Selective etching of aluminum oxide
I wanted a method for Etching aluminum oxide without affecting aluminum. Work being done in chip design.
Senthil Velan
student research - Columbia, Missouri, USA
The chromic-phosphoric acid mixture used to strip anodized coatings should selectively remove aluminum oxide from aluminum. Use our search engine with the search term "strip+anodizing+chromic-phosphoric"
