Stainless Steel Sink/Countertop Refinishing
I need information on the steps to refinish a stainless steel counter top with at #4 finish that has been welded. Any information is appreciated.
Joe Bressi- La Mesa, California
There are various #4 grit finishes out on the market. It is best to match the sandpaper grit to that of the finish then sand it in the direction of the grain. #4 finish typically are short grain finish so it is harder to match the original finish (long grain HairLine finish sheet has a decided advantage over #4 in this department). You may want to try it on a small test piece before the actual piece. Good luck!
Michael Liu Taylor
specialty stainless steel distributor - Dallas, Texas
2001 I recently purchased a vintage "steelcase" steel office desk and was wondering about refinishing this type of furniture. How do I strip the paint off ( 00 steel wool ⇦ this on eBay or Amazon [affil links] ?) and what type of powder coat or clear coat should I be applying to the stripped surface ? Any suggestions would be appreciated, thanks. Sylvain Despres- Ottawa, Ontario, Canada Hi, Sylvain. I don't believe "steelcase" office desks are stainless steel. I believe you will find that they are plain steel. We have several threads on-line here about refinishing steelcase desks. Please see letters 26176 and 48537 for starters. Good luck Regards, ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey May 10, 2009 |
Can you tell me the grit of sandpaper to purchase for refinishing a stainless steel sink?
J.Martinez- Temecula, California
May 12, 2009
