MIL-E-11195 dry time and hardness problems
We have recently been forced to switch from TT-E-516 (enamel, lusterless, quick-drying styrenated alkyd type) to MIL-E-11195 (enamel, lusterless, fast dry, voc compliant). Our production line is experiencing longer dry times and paint peeling after 24 hours. I have been investigating different thinners such as MEK / methyl ethyl ketone, A-A-3007, TT-T-306, and A-A-857 without any success. Are these normal difficulties when switching between these enamels? Is there any adjustments that might help?
Bradley Black
laboratory chief - McAlester, Oklahoma
Both the MIL spec. and QPL were recently revised several times (problem fixes?). Obtain MIL-DTL-11195G and QPL-11195-26 (30 Dec 2003) from ASSIST: http://assist1.daps.dla.mil/quicksearch/ and purchase new material if necessary.
MIL-DTL-11195G indicates that (after thinning with 8 parts A-A-3007) spraying at 8-10 inches should yield air drying times of 6 minutes (touch) and 12 minutes (hard) for a DFT of 0.0013-0.0017 inch. Only A-A-3007 thinner is mentioned.
Ken Vlach [deceased]
- Goleta, California
We are also having this same problem. Have you found any additional resources or have you solved this issue.
Robert Davis
- Texarkana, Texas
