How good is EIS?
I am trying to develop corrosion resistant organic coatings for steel substrates. I use EIS and salt fog test to evaluate performance of the coatings. Sometimes the results do not correlate, which one should I trust? I do not have a lot of time to go for field tests that go on for months. Is EIS a good indicator of corrosion performance? are there better techniques?
Karthik Suryanarayanan
Research Assistant - Cincinnati, Ohio
Hi Karthik,
If the results of salt spray and EIS correlate with one another, then it is a coincidence. Salt spray testing correlates with nothing. When designed intelligently (and this doesn't happen often), it is a test whose results will give you information about relative performance of coatings or pretreatments.
There has been some research done to see whether EIS results will correlate with real-world corrosion behavior, but you will have to search the literature to see whether those experiments are relevant to your work.
George Gorecki
- Naperville, Illinois
