Need pointers on coating polished brass or copper
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
Every time I polish brass or copper, it comes out beautiful. Then I spray an automotive clear-coat. It says to wait 48 hrs. Then use a rubbing compound this on eBay or Amazon [affil links] . I use 1500 grit. Every time I use the compound, the clear coat comes off. The clearcoat looks ok, but it has a texture I want to remove. can anybody give me some pointers on my problem?
Mark Jurkowski
hobbyist - Beaver, Pennsylvania, United States
Hello, Mark. The short answer is probably that brass requires brass lacquer this on eBay or Amazon [affil links] not automotive clearcoat. Good luck.
nikolasbanner
