Is Ospho resistant to Gasoline?
Q. I am restoring an old motorcycle and have light surface rust inside the gas tank. I have used Ospho [adv: Ospho on eBay or Amazon [affil link] in the past, but never in conjunction with gasoline. Will it dissolve off the metal when immersed in gasoline. Is there a better alternative?
Thank you for your help.
Craig Triplett
automobile repair technician - Bryson City, North Carolina
A. I recently took the gas tank out of my 1949 Ford and did just about the same thing your hoping to do to your motorcycle tank. I asked for advice from several people that would know, and settled on the one idea that sounded right to me.
toilet bowl cleaner ⇦ on eBay or Amazon [affil link] was suggested as the way to remove inner corrosion and rust and any old chemical deposits. So I taped off the hole the gas gauge goes in, and poured a quart or so in, then taped shut the filler neck hole. Then I shook it vigorously on each of the four sides and then alternated which side the liquid rested in and left it that way for about ten minutes each side. I poured out the solution, (keeping the old cleaner for future work) and then hosed it out good. Then I blew it out with my compressor, eyeballed it to see if there was any difference, and not really seeing any, did it all again.
I figured that was as good as it was going to get, so after it was dry inside, I poured in this gas tank coating fluid purchased at the local old Ford place (Little Dearborn Ford) in Minneapolis, (sorry I can't remember what it's called) and left it coating each of the four sides repeatedly as during the cleaning. I did that twice also, and when it was cured it was such a nice smooth and hard surface, that I then did the filler neck and the bottom of the gauge also to finish it all up.
I'll do the same to my own motorcycle tank next spring.
Carl Goulding
- Minneapolis, Minnesota
Using Ospho inside a gasoline tank?
Q. Is there any reason not to use Phosphoric acid (OSPHO) in a motorcycle gas tank to convert rust? (Like a reaction between iron phosphate and gasoline) Any safety tips would be appreciated.
Dan Thurman
- Coos Bay Oregon USA
November 28, 2017
Gas Tank Sealant
November 2017
A. Hi Dan. Unless I misread, Ospho tells you to scrub the white remnants of the reaction off the surface, which crud sounds problematic inside a gas tank. I don't think Ospho is the right answer. But good luck.
