Restoration and rechroming of wire shower caddy
I need a single shower caddy (Height 20 inches, width 13 inches, depth 4 inches) that I think is made of steel wire welded together stripped, restored to a smooth finish and then rechromed.
Michael Sullivan
Home owner - Collegeville, PA, U.S.A.
Hi Michael, that is not any problem if this shower caddy holds special significance to you ... as long as you realize that stripping, polishing, and plating a single item like this takes a couple to a few hours, so it will probably cost several times as much a new one. Regards
