Artist endeavors to turn 304SS a mottled blue
I am trying to blue stainless steel 304 grade 3/16' thick on a 48" giant butterfly sculpture. When I apply heat the wing turns brown with just hints of blue. Is there a way to get a mottled blue effect on this piece.
william colburn
metal artist - Fairhope, Alabama
Sounds like your not getting it hot enough, when heat coloring steels a brown/copper color comes before the blues. Just try to heat it up hotter and make sure you use a clean flame and you should get some great blues (especially if it has a good polish) dark blue will come first with a light blue color following.
Good luck,
Jason Aube
- Flint, Michigan
