Thread 260/70
Stripping silver and nickel from PCBs
We need to remove the nickel plate (immersion nickel) the finish down to the copper; what is the best chemistry to strip off the nickel from the copper leaving the copper body and key of the copper surface smooth and clean? We need to remove the silver plate
(immersion silver) from copper also what is the best chemistry to strip off the silver and keep copper surface clean?
Thank you very much.
PCB mfgr. - Salt Lake City, Utah, USA
publicly reply to Yanlu Zhai
September 22, 2010
hi, don't know if ill be of any help. I am but a humble plater. but when we need to strip nickel off copper based material we use a sulfuric dekote @70-90 deg[its normally electroless nickel off brass] but I'd guess its the same.
i forget the exact make up but its along the lines of 110g dekote base salt ,10ml dekote activator , 50 ml sulfuric acid conc. per litre [im sure you could verify this by goggling.]
i found its best to start with say 600ml of water add the acid then get to temp , add the base salt and mix till dissolved , then the activator, and top up to 1 litre with water.
and for silver [99.999] on a copper base we'd use a sulfuric/nitric @50 deg
95% sulfuric acid conc. and 5% nitric acid
be sure to be well ventilated and take extreme care with the nitric sulfuric as splash's with it are extremely painful/dangerous.
i think this is what you were after if I read the question correctly , hope it helps.
- exeter devon uk
publicly reply to Leigh cox
