Protection of brass/brown war plaque
Hi ...I'm an Industrial Spray painter from New Zealand ..a client has approached me and asked If I knew of any process/chemical that can be used to protect a recently fitted war memorial Brass plaque with brass letters and brown background ...would a 2K clear coat effect the brown surface of the plaque ? ...cheers
Greg Hay
Industrial spray painter - Ashburton, Canterbury, New Zealand
Things should always be tested, perhaps on the back of the plaque, especially because today's high-tech finishes may not always actually be the traditional finish they appear to be. There are half a dozen ways to simulate brass these days.
But I doubt that just about any clear finish will affect either the shiny brass or the browned brass. There is a big advantage to brass lacquer, though, which is easy removability.
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
