Enthusiasts helping each other -- No cost, No registration, No damn popups
Carpenter worries about stainless steel to aluminum galvanic corrosion
Will a stainless steel bolt put in a aluminum bracket cause a galvanic corrosion.
Chad Steffens
Carpenter Foreman - Mayfeild Hts., Ohio
Sometimes I feel like a politician, unable to give a straight answer because it usually "depends". But the answer is basically "yes", it can under certain conditions.
