Inspecting a Glass Lined Vessel for Holidays
I am looking for a procedure to holiday test a glass lined vessel.
Bill Hohl
Inspection - Buffalo, New York, United States
Hi Bill. Spark testing is probably the usual method. Is the vessel metallic? If not, does it have or can it have aluminum foil behind the lining in critical areas? If so, spark testing should work.
