Fiberglass Delamination problems & solutions
Delamination of fiberglass from ABS
Q. We are a manufacturer of pressure vessels. The filter tank is made of fibreglass. We are using an ABS component. Unfortunately, when we laminate the fibreglass onto the ABS components, it delaminates. What and how can we do to give a good bonding between fibreglass and ABS to avoid delamination?
KW Lee
Manufacturer - Rawang, Selangor, Malaysia
A. Hi, cousin Lee. I am a little unclear. This is not a lined tank? Rather it is a fiberglass tank and there are some ABS components like a mounting bracket or such that you want to attach to the tank by laying it onto the wet resin but you're not getting adhesion?
Although I'm not fully understanding your question, ABS is a multi-component plastic which is eminently etchable for outstanding adhesion. The "chrome" grills on millions of cars & trucks are copper-nickel-chrome electroplated ABS and the metal sticks despite blazing sun, frigid cold, gravel strikes, and carwash brushes because the ABS was etched to a sponge-like surface ... it ought to work for you. Please get back to us with more detail.
A. Hi KW
As Ted pointed out, your spec was a little unclear.
Whereas 'we' did a lot of dual laminate work, it was normally bonding fibreglass to a thermoplastic.
There are, as you must know, proprietary chemicals for bonding, say, FRP to PVC ... but perhaps the following method, although now antiquated, might help you.
You get some ABS cement ... add ABS to it to a consistency of, say, 20% solids. Then you get some fibreglass heavy woven roving. You are now ready to coat that ABS part with the heavy cement and IMMEDIATELY press on the woven roving. Let it air dry ... and if you do it correctly, then one link of the WR will be embedded in the cement, the other one exposed ... which now allows for a perfect FRP bond.
This is how the world's first successful dual laminates were made ... 1963-ish by Alcore Fabricating in Richmond Hill, Ontario ... using PVC albeit with the appropriate solvent, THF.
If this helps you, please let us know. Thanks.
freeman newton portrait
Freeman Newton [dec.]
How to Repair UPVC Lining on Fiberglass
Q. I have a task to supply a product that will repair a UPVC lining on a tank made of GRP, the tank contains ClO3 (chlorine trioxide) is there a product that will bond to the GRP and also the UPVC?, I would be grateful for any assistance.
John Roope
Zycon pty ltd - West Australia
A. Hi John,
I don't quite fathom your question but will try to !
When you have a PVC sheet and want to bond fiberglass to it, there are now commercially available materials to achieve this. These you'd probably get from the resin supplier. But any good dual laminate fabricator could give you advice.
In the DARK AGES we used to make up a heavy PVC cement using THF and drop on some heavy glass woven roving ... and when the PVC 'dried', ah, we have a good lock to the exposed section of the roving... a world's first back in 1962-ish.
Whatever you do, don't expose the FRP to the ClO3 and try, of course, to weld any new sections to the adjoining PVC.
... just had another glance at your request ... there's no product I know of that will successfully bond PVC to an existing and CURED FRP build-up .... with the above mentioned approach, the 'bonding agent' to the PVC only allows a bond to the 'new' and uncured FRP ... the only other thing I could think of is to use epoxy BUT again you'd have to use that initial bonding agent.
Repairing Fibreglass Acid Bath
Q. We have just emptied our 750 litre acid bath when it developed a leak. It holds Hydrofluoric and sulfuric Acid. The construction is MS coated with Fibreglass.
My question is this:
What is the best resin & glass to use for this repair until a new bath can be sourced and manufactured?
Michelle Sindholt
Metal coating shop - Brisbane, Qld Australia
January 1, 2009
A. Hi Michelle,
Who in der Hell said that FRP would be good for HF acid?
Surely there are some good HDPE suppliers using moulded tanks in your neighborhood, try them !
Further, FRP tends to wick ... osmotic attack .... hence structurally the m.s. side would be attacked.
For an el quicko build up, use epoxy. But first of all, grind down the attacked areas.
A. I agree that FRP is not suitable for acid solutions containing HF, but, with a PVDF surfacing veil inside the fiberglass, bonded to it with epoxy and covered with a gel coat of epoxy, it may work for many years.
Lyle Kirman
thumbs up sign Thanks Guys, for your response, we have repaired the tank and is holding well. Contact has been made with a business who has done lots of work building tanks for HF, The repair was done to their spec.
Michelle Sindholt
powdercoating shop - Logan Village, Queensland, Australia
Q. My chemical bath dimensions: length 14 metre x width 1.5 metre x depth 2.5 metre. It is for degreaser; concentrated hydrochloric acid; flux; molten zinc; water.
At present the material is constructed from reinforced concrete.
My question is how to detect any leakage before it becomes a hazard.Something similar to an early warning signal to alert the user.e.g. there is a crack in the holding bath.
Yi Gao
A. Hi Yi. Concrete tanks of that general size are often used for architectural anodizing projects, quite similar to your degreaser, acid, and flux tanks; and they can be equipped with various corrosion resistant lining materials.
A sometimes-used technique for leak detection, although imperfect, is an angle shaped strip of heavy gauge aluminum foil running around the tank where the four sides hit the bottom before the tank lining is applied/installed. Then some sort of conductivity meter is put into a circuit with a probe in the solution being one leg, and wiring attached to this strip being the other leg. It's not perfect because it doesn't work until the strip is wetted by the leak, but it does work.
However, I am flabbergasted by your reference to "molten zinc"! I can't even imagine a concrete hot-dip galvanizing tank :-) Luck & Regards,
Delaminating fibreglass hand basin
Q. I have a 20 year old beige fibreglass hand basin which is locally peeling / delaminating. How do I go about repairing it (assuming it is repairable)?
Francois Joubert
DIY - Adelaide, South Australia, Australia
August 21, 2014
A. Hello Francois. As a personal opinion from a consumer who has faced the same problem a couple of times, not a professional opinion, I think you should replace it unless it is very special to you for some reason (special dimensions, aesthetic appeal, sentimental value). Water has soaked into it and caused swelling, plus the gel coat has been destroyed. It is perhaps possible to sand away the gel coat, dry it out, finish sand it, and apply a new gel coat (perhaps with materials from a boating store; boats are repaired this way) ... but it's a huge amount of work for something that can be replaced very inexpensively, and you'll never get it quite perfect. Best of luck.
Readers, this site has 60,000 related topics; if this page didn't answer your question, please try a more exacting search term in our search engine or post your own question.
