Lodging of steel balls in Copper U-bend tubes
SIR, I AM CARRYING OUT BURNISHING PROCESS ON COPPER U-BENDS OF 3*8 (9.5MM) DIAMETER. THESE U-BENDS ARE REQUIRED FOR AIR CONDITIONING AND REFRIGERATION PURPOSE. THE PROBLEM THAT I HAVE ENCOUNTERED IS ABOUT LODGING OF STEEL BALLS IN THE U-BENDS AFTER UNLOADING. IT REQUIRES MANUAL WORK TO REMOVE THE STEEL BALLS FROM THE U-BENDS, WHICH IS TIME & MONEY CONSUMING. SO KNIDLY SUGGEST A PROCESS WHEREIN I CAN REMOVE THESE STEEL BALLS DECREASING OR ELIMINATING MANUAL WORK. THANKING YOU.
NIRANJAN S. KULKARNIsales engineer - THANE, MAHARASHTRA, INDIA
Niranjan !
There are perhaps 4 ways to 'bend' a pipe. Sometimes heat is used or has to be used.
l. Do nothing at all except to form it over a mandrel in which case you'd get a flattening of the bend
2. To use a spring inside it
3. To use sand
4. To use a so-called rosin (which sets hard and prevents kinking) but this is an expensive method and suitable for, say, high quality, tight radius bends
But you infer, I assume, that the tubing is filled with balls which sometimes, often (?) get stuck as the bend is made.
a. Perhaps use some heat to bend?
b. Perhaps use a larger radius?
There is no easy fix. Have you tried the spring approach?
And just HOW does the competition get over this problem?
Freeman Newton [deceased]
