Set painter needs to remove silvering from mirrors
Q. Dear friends,
I am looking for the solution to removing the silver finish on the back of mirror, I spend to many hours grinding and scraping it off , is there any chemical that will remove or at least disfigure the silvering? I know how to remove the brown paint that is on the back over the silver, my job requires that I do this on a regular basis, and I have not yet been able to get this right.
Sincerely,
RON EMMONS
FAUX FINISHER / SET PAINTER - LA CRESCENTA, California, USA
A. Got a problem removing the silver from the back side of a mirror after you've removed the paint. This is what you do and you better be well vented with a fan. Pour some Muriatic Acid on a rag placed on the silver, give it a few minutes, then with rubber rubber gloves this on eBay or Amazon [affil links] take the rag and put it a steel can. Gently wipe the remaining silver off, you may have to use some more Muriatic Acid.
Good Luck.
Doug Strom
signwriter - Lancaster, California
Q. How dangerous is it to strip silver from the back of a mirror, for example, using muriatic acid this on eBay or Amazon [affil links] or other chemicals?
David Higgins
retired - Oakville, Ontario, Canada
A. Hi, David. Sorry, but questions like that aren't easily answerable. How dangerous is it to do an injection? A nurse at a flu clinic can do a hundred patients an hour all day, every day, and sleep as carefree as a baby, while an untrained person may kill you on their first attempt :-)
Muriatic acid is sold in hardware stores; it's not plutonium. Still it can blind you or burn you. A high priority is proper ANSI-approved goggles this on eBay or Amazon [affil links] , as most people would be more devastated by blindness than a burn. Another thing to remember about muriatic acid is that it is a gas dissolved in water, so it fumes; the fumes can ruin the plating on your bathroom fixtures and the finish on your stainless appliances. Best of luck!
Q. I have the same question about removing the silver from mirrors, but I know that there must be a better answer out there somewhere. I remember doing this project in art class as a kid and you could remove some the silver and than replace it with a picture.... I doubt we used a harmful chemical...but I don't remember what the teacher used.
Sammy [surname deleted for privacy by Editor]
- Torrance, California
A. To remove the silver coating from the back of a mirror after the grey or black paint has been removed, pour Lysol Toilet Bowl Cleaner that contains BLEACH (green bottle), let set for a few minutes until the liquid cleaner turns darker or bluish then rinse with water.
Paul Selway
- Montreal Quebec canada
March 30, 2011
A. I have just removed the silver backing from a mirror by laying newspaper in a plastic bag big enough to hold the mirror, soaking the newspapers in vinegar in bulk on eBay or Amazon [affil links] . Just make sure you lie plastic bag of garbage bag down then the newspaper then the sliver or copper lying on top of the newspaper for at least 24 hrs. My mirror is approximately 55 yrs old.
Ann Renfroe
- Hearne, Texas USA
April 30, 2016
