Making carbon steel sheet metal art look like bronze
I'M MAKING METAL SCULPTURES FROM SHEET METAL & CARBON STEEL WELDING RODS. I WANT TO COLOR THE OBJECT TO LOOK LIKE BRONZE. WHAT IS THE EASIEST WAY? PATINA? I MAY WANT TO USE DIFFERENT COLORS LATER.
CARLTON GOUGHNOURhobbyist - FARGO, North Dakota, USA
Paint is the easiest and offers corrosion resistance, Carlton. You should be able to achieve a bronze color on steel with a Modern Options / Sophisticated Finishes [affil links] patina solutions as well.
