Replacement for Hexavalent Chrome
I'm researching on multilayers protective-decorative nickel-chromium. Due to the environmental problems of hexavalent Cr, it have been replaced by using instead, trivalent Cr. However it's known that worldwide there are alloys such as Tin/Cobalt, Tin/Nickel, etc as replacement for Hexavalent Cr. It's possible to use pulse plating to make this kind of alloy? Could you send me information about it? (papers, patent numbers, etc)
Thanks a lot.
Omar H [last name deleted for privacy by Editor]
University - Puerto Ordaz, Bolivar, Veneuela
I seem to recall from my university days that researching involves searching.
Ken Vlach [deceased]
- Goleta, California
Although chromium plating is often done from "home-brew", most electroplating, including trivalent chromium, tin/cobalt, and the other replacements are done from proprietary solutions. So you could start with suppliers like Atotech, CST Surtec, and Macdermid for this.
Ed. note: You may want to hear "The Lost Art of Tin-Nickel Plating".
