Thread 255/14
Water meter mfgr needs durable and safe aluminum finish
Hi,
I am a design engineer for a UK based company that designs and manufacturers water meters.
I am looking for information about corrosion resistant finishes applied to Aluminium alloys that are used in the food industry.
I have a project where I am considering using AL (LM25TF) for the main body casting of a water meter, this will require some form of corrosion protection. As this meter could be used in drinking water supply a finish is required that is safe for the water to come into contact with, the food industry being the most obvious application.
If anyone could provide any information about recommended processes/grade of finish I would be most grateful.
Many thanks,
Nick RollingsWater meter design and manufacture - Luton, Bedfordshire, England
publicly reply to Nick Rollings
Hard Anodize Per MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA] Type III class I with a DI-Seal is a possibility. As far as I know the process is accepted as a "food grade" coating and should offer quite good corrosion resistance as long as the pH stays fairly neutral.
Bill Graysonmetal finishing - Santa Cruz, California
publicly reply to Bill Grayson
High Phosphorous Electroless Nickel, food grade approved (no lead or other heavy metal traces). Extremely durable for aluminum in contact with drinking water.
publicly reply to Guillermo Marrufo
