Hotplate user wants to electroplate them to improve heat transfer radiation
We have several hotplates used to cure coatings on paper. The hot plates are approximately 1/8" above the paper and they operate at 375 F. I would like recommendations for plating to shorten the cure time by improving the heat transfer rate.
Jerry K
Air and liquid filters - Bloomington, Minnesota, USA
Look into using infra red heaters vs hot plates. I think that the only way that you will get a better heat transfer with the hotplate is to decrease the spacing, which I will guess will not be easy.
Infra Red heating is a good alternative to conventional heaters and can be more efficient as James says. However, if that is not to your satisfaction, try doing what the cooking sector does - to prevent localised hotspots in the more exclusive pan ware, they often have a thick copper coating on the base of the pans. Copper is a very good thermal conductor and equalises the temperature across a surface. Unfortunately you do not say what the hot plate is currently made from, so I do not know if this is feasible
