No cost, no passwords, no popups
(earnings from 'affiliate link' purchases make the site possible)
Lacquer Coating
We do a lot coating of brass. What is recommended as a most durable lacquer on the market, that will last for years? Also is there a spray-on lacquer that is stronger than E-Coating?
Anthony M Guglielmo
Metal Finishing - Pelham, New York, USA
Hello Anthony,
A urethane or baked coating are sprayable and comparable to e-coat. Hope that helps.
Jake Koch
G. J. Nikolas &Co.,Inc.
Bellwood, Illinois
nikolas banner ad
The system of Acylic Amino can give a good hard film in comparison to E-coats. Even a good Thermoplastic Acrylic Coat can give a durability for a limited period.
Tushar Kathrecha
- Rajkot, Gujarat, India
Dear Sirs,
Have you considered transparent polyester powder coating. Most transparents contain UV absorbers - but you must carry out evaluation to check on resistance to darkening - adhesion and scratch resistance should be much better than any liquid product you may have tried up to now.
Terry Hickling
Birmingham, United Kingdom
You can use Incralac this on eBay or Amazon [affil links] -special lacquer for copper and its alloys (USA product, acryl based) or Ormocer lacquer (polysiloxane based, EU product).
You can also try Nikolas #9778 Acrylic Urethane! Should I list the prices here too?
Jake Koch
Bellwood, Illinois
nikolas banner ad
Ed. note: Not necessary, Jake! The readers thank you for making this forum possible and are mature enough to recognize that there can only be helpful forums like this available for them if they give first crack to the site's supporting advertisers like yourself.
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
