Removing lead paint from brass hinges
Dear Sirs:
I have some brass hinges that have based lead paint on them. I would like to remove this paint so that the true finish will show. Please advise what to use to remove this lead paint.
Ralph S [last name deleted for privacy by Editor]
hobbyist - Mooresville, North Carolina, USA
Mineral Spirits
mineral_spirits
I could be wrong, but I don't think the amount of lead in lead-based paint is sufficient to materially affect what solvents will remove it. So I would start with mineral spirits this on eBay or Amazon [affil links] or turpentine this on eBay or Amazon [affil links] . While a caustic cleaner can remove paint, it could also etch the brass.
But before you start, check with your public hazardous waste center and see if they have any comments, suggestions, or restrictions based on the fact that the paint must be disposed of after it is removed.
