Wetting Agents in EN Baths: Useful, but Usually Unneeded
Summary for wetting agents in en baths Discussion
wetting agents in electroless nickel baths are usually not needed, according to the thread. Frantisek Haas asked why three EN baths from different suppliers came without a wetting agent and whether that could explain pitting on low-phosphorus nickel deposits. Guillermo Marrufo replied that chemistry varies by supplier and suggested checking with the bath makers. Trevor Crichton explained that alkali EN baths generally do not use wetting agents, while some acid-based baths do; in alkaline systems, caustic soda already provides a built-in wetting effect. A later answer added that EN baths often do not need surfactants because hydrogen bubbles leave the surface quickly enough, and that many wetting agents can become organic contamination. That answer also said pitting is more often caused by poor cleaning, residual contamination, or pits in the base metal than by the absence of a wetting agent.
Q. I am starting into electroless nickel plating. I have tried 3 different baths from 3 suppliers, and all baths apparently came without wetting agent. Is there any reason to use no wetting agent in EN baths? There was something like pitting on the parts plated with low-phosphorous nickel, so I thought that proper wetting agents would help. I will appreciate any experience or opinion.
FRANTISEK HAAS
glass products – JABLONEC N.N., BOHEMIA, Czech Republic
A. This seems to be a complaint to your suppliers. What do they have to say about it? Every chemistry is different, so it is very difficult to recommend an addition not knowing what is in your bath,
G. Marrufo-Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
A. Good question. Generally alkali electroless nickel baths don’t have wetting agents, but many acid based baths do include them. Wetting agents are there to make the substrate more wettable and with alkaline baths, especially ones using sodium hydroxide, have a “built-in” wetting agent, namely caustic soda ⇦liquid caustic soda in bulk on
. Conversely, acid based baths don’t have this luxury.
Q. Guillermo,
I don’t complain to my suppliers, I only wonder, why there is no wetting agent in EN baths. Other weak acid processes (electroplated nickel or zinc) always use wetting agents, so why not EN? Is there any fundamental reason? Trevor says, there is not. Many thanks for your responses.
FRANTISEK HAAS [returning]
A. Wetting agents are usually not necessary in electroless nickel plating solution because the hydrogen gassing occurs quickly enough that bubbles leave the surface without causing pitting. Why add something (wetting agents, i.e., surfactants when not needed?) Some surfactants are or become organic contamination to electroless nickel plating solutions. If there is oil or other organic contamination introduced into the EN plating solution, wetting agents will help temporarily, otherwise they should be avoided. There are only a few wetting agents suitable for electroless nickel solutions. If pitting is encountered it is almost always because of improper preparation, i.e., something is left on the part, not removed by cleaning, or there is a pit in the basis metal that has entrapped cleaner or other materials.
don baudrand
Don Baudrand
Consultant – Poulsbo, Washington
(Don is co-author of “Plating on Plastics”
and “Plating ABS Plastics” eBay
AbeBooks
affil links])
Choosing surfactant for electroless nickel plating
Im currently doing research on electroless nickel plating (with pH 4 and operating temperature at 80 °C), and I want to purchase surfactant to add in it, but there are so many kinds, nonionic, anionic, cationic, and amphoteric. I’ve seen some people using nonionic (Triton X-100) and anionic (SDS) most frequently. which type of surfactant is the most suitable for metal plating bath that the surfactant won’t participate or interfere with chemical reaction of plating bath?
kevin lee
– san jose California, USA
December 17, 2014
A. Hello Kevin,
I have to fully agree with Don Baudrand’s answered letter above your question. I think Don covered all the bases.
Mark Baker
Process Engineer – Phoenix, Arizona USA
December 20, 2014
finishing.com is made possible by …
