Mil-A-8625 Sodium Dichromate seal: make up and troubleshooting
QUICKSTART:
(to help readers better understand the Q&A's)
Those who don't clearly understand the references to mil-specs and types and classes on this page may want to quickly review our "Introduction to Anodizing of Aluminum".
Q. I want to install a small 185 gallon Sodium Dichromate seal tank for MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA] MIL-A-8625 TY IB & TY II anodized parts. I have found two makeup plans, but I am uncertain as to how to calculate the amount of sodium dichromate to add to DI water. Can anyone show me the calculations?
Plan 1- Shows 56 to 64 g/l of Sodium Dichromate.
Plan 2- Shows 4.0 - 6.0 percent solution by weight of Sodium Dichromate.
John McGuirk
Metal finisher-Mil/Aerospace - Oldsmar, Florida, USA
A. They are nearly the same. Water weighs 1 gram per ml, a liter is 1,000 ml, so 4 -6% would be 40 to 60 grams of dichromate. Whatever the specification calls out is what you want to use.
A. Here is my take on the calculations you need:
185 gallons * 3.785 Liters/Gallon = 700.3 liters.
56 grams/liter = 39216.87 grams / 453.59 grams/pound = 86.46 lbs. of NaCr2 For 64g/liter, 98.81 lbs. of NaCr2.
For a 4-6% solution by weight:
185 gallons * 8.33 lbs./gal = 1541.05 lbs., .04 * 1541.05 = 61.64 lbs. NaCr2, .06 * 1541.05 = 92.46 lbs. Na Cr2
I am not in the plating industry, just a chemical engineer looking for pot metal restoration help. These are what I would consider the correct calculations, however you might want to confirm with another source before using.
Mike Jones
Indiana, USA
Q. I am a lab tech/ intern at a metal finishing company, and we came across a problem with the sodium dichromate seal tank. The pH of the tank is 6.0, which puts it within the range of 5.6-6.0. The sodium dichromate concentration is 6.4 oz/gal which equals to around 47 g/l which is also within range. However, the parts go in charcoal black, and are coming out green (unacceptable). Possible problems?
Chris Sierka
Lab tech - Greensburg, Pennsylvania
May 24, 2012
A. Need more information. What kind of anodizing? Alloy? Why dark gray going in? Is it dye? You always shift the color of the dye with dichromate sealing. A greenish tint is normal on some alloys with regular non-dyed Type II anodizing on common alloys. What thickness? What temperature of anodizing?
robert probert
probertbanner
May 25, 2012
A. I agree with Mr. Probert, we need some more info. I can only assume that this is type II anodize, in which case I imagine they will be a yellowish green color. As Mr. Probert asked, why are the parts so dark?
Scott Merritt
- Eastman, Georgia, USA
July 11, 2012
A. Unless it is 8625 Type III Clear …
Build up on Type III 8625 will begin with a Grey to a dark Grey in a bath of 20-25 °F; the dichromate will look like an olive color
Wendy McGaha
Aerostar Industries, LLC - Huntsville, Alabama USA
July 26, 2018
Sodium dichromate seal tank - pH adjustment
Q. Hi all,
We sulfuric anodise to MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA], and are having minor powder issues. From trials it does not appear to be an anodising tank issue, and parts have been stopped at this stage and inspected with no trace of powder (white). It appears after sealing in sodium dichromate with (yellow/green) powder. I have reduced the sodium dichromate content to mid limit (50 g/l), but still powder issues continue ...
I wish to make a minor adjustment to my sodium dichromate seal tank from 5.8-5.9 pH to 5.6-5.7 pH range. What acid is best to use without further side effects? (I have seen acetic acid this on eBay or Amazon [affil links] mentioned).
Thanks Ian
Ian Armour
Engineer - Bristol, U.K.
November 12, 2018
A. Chromic Acid
robert probert
probertbanner
November 13, 2018
A. Along with adjusting your pH, look for the possibility of contamination in your Dichromate Seal. One possible source is stray Nickel from a nearby bath, entering as rinse overspray, dragover, or even condensed mist dripping out of a shared ventilation system (speaking from experience here... luckily it was an easy fix). If you take a sample from your Dichromate Seal bath, pH adjust it UP to about 8-8.5 with Sodium hydroxide, and see particulate settling- you've got a potential problem, and I would have it sent out to be tested for Aluminum and Nickel (if you use a Nickel seal too) levels. Nailing down the actual contaminant will also help you nail down what you can do to prevent recurrence.
Bath age is important as is making up fresh baths with deionized water. I run my seal bath at pH 6.5-6.7 with no powdery residue until the bath gets pretty old and has to be dumped for contamination, and still don't see salt spray issues even at that point. One clue I use that the bath is getting dirty is that the pH starts to drift slightly downward.
You may in fact solve your problem by adjusting your pH as planned, but this is another thing to monitor over time.
rachel_mackintosh
Rachel Mackintosh
lab rat - Greenfield, Vermont
November 20, 2018
