Student needs plant layout info
Dear Sir, I need a an article or some information about a plant layout of a company that has been worked on or has to be worked on.
Golnaz B.Student - Tehran, Iran
Your inquiry is a bit too brief for us to really understand the question. But you will see general layouts of metal finishing installations in journals such as Metal Finishing, Plating & Surface Finishing, and Transactions of the IMF if you can get a hold of any; and there is an article with plating-line-related info on-line here as "Plating Shops for the Nineties and Beyond".
