Diecast aluminum alloy cleaning
Q. What is the best alkaline chemistry to clean diecast aluminum alloy surface?
Geetametallugy - SJ, California, USA
A. Hi: proprietary cleaners formulated for cleaning aluminum are available from any of the plating process suppliers listed in our Chemicals directory (or your local yellow pages). Properly formulated cleaners involve saponifying agents, wetters and emulsifiers, deflocculating materials, chelates or sequestering agent, buffers, inhibitors, and more -- tailored to the particular dirt. Getting all those individual materials if you knew a good mix, would be a hassle. Good luck.
A. The choice of the appropriate cleaner depends on the "soil" to be removed.
James Watts- Navarre, Florida
A. Hi The choice of the cleaner depends on the chemical composition of your alloy and the shape of your product too. first you must be have a chemical analyses for your alloy to choice the best cleaner formula and technical method for your alloy thanks
aly gomaa- cairo- egypt
