Electropolishing machine set up questions
I want to make setup of electropolishing machine..small set up for academic purpose ... how can I start and how can I be able to get some design or broad component list of simple electropolishing machine ... thanks .. I am working as a lecturer in vjti engineering college in Mumbai ..India.. ok
Sachin
teacher - Mumbai, Maharashtra, India
If you teach in an engineering school, the library should have all of the references that you would ever need. Also, it would be more believable than anything that you get from the internet, unless it is an internationally recognized expert.
Ed. note: A couple of those books with coverage of electropolishing are the Electroplating Engineering Handbook this on eBay, AbeBooks, or Amazon [affil links] and the Metal Finishing Guidebook. Good luck!
Knowing Engineering Colleges in India, I would not expect this kind of literature there, not in the developing countries. There could be exceptions.
Sachin, have you contacted electroplating chemical or machinery suppliers and see if they have any literature? The other source would be NACE International in Mumbai. Contacts are Prof. A.S. Khanna, Corrosion Science and Engg, IIT Mumbai, and Dr. M. K. Tolani, Surface Eng. section of Metallurgy Div. BARC, Mumbai. Tolani probably would have knowledge of electropolishing. I am sure IIT library would have some books.
Mandar Sunthankar
- Fort Collins, Colorado
