CHROME PLATING ON ABS PLASTICS
CAN ANY ONE HELP ME OUT IN MAKING PALLADIUM CHLORIDE SALT FROM PALLADIUM METAL.
Murat Cetin
- Izmir, ISIKKENT, Turkey
This is basic chemistry and is the field of very large mining and chemical companies, so I doubt anyone will help you. But if you attempt it, you will soon discover the capital investment is far beyond what it takes to plate on plastics. If, after all you succeed, you will soon forget about plating and dedicate to basic chemistry.
Guillermo Marrufo
Monterrey, NL, Mexico
PREP PdCL2-ref book. WASH 2.5G Pd with concentrated HCl for one hour. Put Pd in glass and add 13 ml con HCl and 4.5 ML conc. HNO3 cover the beaker [beakers on eBay or Amazon [affil links] to prevent dust with glass, and keep for some hours. Afterwards stir and heat over a water bath until dissolved. I believe you can use this solution for activation, after the addition of required HCl.
Good luck
Cair Shishani
Khair Shishani
m&m metallizing banner2
