Battery acid stained concrete
Many years of servicing, and replacing golf cart batteries, has left a very large area of concrete, heavily stained by battery acid. I have tried many different compounds and cleaning solutions, to no avail. Any ideas? Thanks!
Ron Preder
Golf cart repair - Indio, California, U.S.A.
My guess is that the top of the concrete has been eaten by the acid and stray dirt and oil have become embedded in the very rough surface. Try a high pressure water spray, if you can and then paint it with a cement paint or a poly urethane.
