Recipes for platinum electroplating
Q. Hi..
I am looking for the recipe for electroplating platinum on either copper, Ni or stainless steel disc. Also kindly refer some good books on the same. If anyone has any idea kindly let me know.
Aparna Prabhakarstudent - Baton Rouge, Louisiana, USA
A. Platinum plating:
platinum diaminonitrite...16 gm
ammonium nitrite..........100 gm
natrium nitrite...........10 gm
ammonia...................50 gm
water.....................1 lit
3-10 A/dm2,90-100 °C
Q. I need this solution for my student project too; could anyone tell me other data for this electroplating bath such as: pH, etc.
ali feizabadi- tehran,iran
December 9, 2015
A. Hi Ali. I don't know where Goran's formula came from, so I can't suggest a proper pH range. But Lowenheim's "Modern Electroplating" →
contains 5 formulas for platinum plating baths, plus a molten cyanide bath and an electroless bath, and it includes references to the original papers on those 7 baths.
But remember that proprietary baths are a more direct route to getting good plating than starting from 50-80 year old formulas. Also, although Aprana called them "recipes", remember that most people have a general understanding of cooking but no familiarity with electroplating, such that a recipe may be all they need for cooking ("... add three beaten eggs") -- whereas if you have no familiarity with cooking, such recipe instructions may be of little value. Good luck.
December 2015
Q. Hi Ted
Thank you for your response
I am searching for an appropriate platinum electroplating bath for nickel superalloys; I would be grateful if you could help me on this.
- tehran, iran
December 10, 2015
9th Edition, Vol. 5
"Surface Cleaning, Finishing & Coating"
on eBay or Amazon
A. Hi Ali. I'm trying to help you, but I get about 50 new requests every day, and I don't have a spare minute beyond handling the postings here to do any research on the topic for you. The only way I can help you is by making suggestions for you to follow, which I am doing :-)
a). Find a distributor of plating processes in Tehran and talk to them about your needs.
b). Find someone local who has a copy of Modern Electroplating and read the subchapter about platinum plating.
c). Try to obtain reprints of the technical references in the Modern Electroplating text.
d). Superalloys are very passive, and getting them activated for plating is very difficult. A Wood's Nickel Strike might do it, but also take a look at ASM Handbook, Vol. 5, which has a chapter on activating exotic alloys. Good luck.
December 2015
