Nickel strike
Hi !
I have a problem concerning nickel plating. I am nickel plating a part consisting of copper, brass, and stainless steel. Before the nickel plating I do a plating in a nickel strike, just to cover the stainless steel part. My nickel strike is of sulphate bath, with almost 400 g/l nickel sulphate and about 22 g/l sulfuric acid. After changing the nickel strike, it plates really bad. After 7 min. in the nickel strike only some of the copper, brass, and stainless areas are covered with nickel. Do you have any comments to that.
Michael Junker
Plating shop - Nordborg, Denmark
First of three simultaneous responses --
Nickel strike should contain the following ingredients: Nickel chloride 120-240 g/l + Hydrochloric acid 4-12% V/V.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Second of three simultaneous responses --
Try Wood's nickel strike. Nickel chloride 225g/l, hydrochloric acid 10%.
Neil Bell
Albuquerque, New Mexico
Third of three simultaneous responses --
I suggest a sulfamate nickel strike consisting of 60-70 g/L nickel as nickel sulfamate, 30 g/L boric acid. Lower the pH to about 2 using sulfamic acid, then to 1.3-1.5 using hydrochloric acid. This strike has better covering power and will plate on all the metals as well as activating the stainless steel. Use 30-60 Amps/sq ft current density.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
           and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
